Artnet dmx lumiverse mapping
Wai fphk
Post by Wai fphk »
Hello Resolume , I had some questions about the dmx output patching for bunch of led pixel bar to create a big screen , on the universe setting it’s okay I don’t have any problem but …. I want to know is there any layer I can create to separate those led bar with different color or group so I can easily to select the led bar ? Because it have a lot of 176ch led bar and like 600pcs total and I’m using over 200 universes to run it ….
Thank you very much for support and cheers
Re: Artnet dmx lumiverse mapping
Wai fphk
Post by Wai fphk »
Thank you very much for your email , those link im understand this is about the video layer group assign to different slice but how to make a different layer on the advanced output to create some group to separate different artnet universe ?
lol i just see all the default cyan color on all the rgbw fixture at the patching screen
by the way , i can export the patch data to xml file , correct ? maybe i will try to import this xml file to capture visualiser im not sure caputer is it possible to import this patching file instead of i need to do the patch twice .....
Hmm…: I tried the xml exported today but it’s quite sad that those xml structure from resolume is different than what Capture visualiser can listen …. Is there any xml converter can make it go into capture visualiser?
Thank for the support !
Wai fphk wrote: Sun Sep 03, 2023 22:13 how to make a different layer on the advanced output to create some group to separate different artnet universe ?
The advanced output is explained on our support page in detail here: https://resolume.com/support/en/advanced-output
Adding Screens / Lumiverses is what you're looking for in particualr I think.
I don't think other software can read our xml formats, but maybe it can understand direct Art-net data?
