Feature requests
DIGILIGHT
Feature requests
Post by DIGILIGHT »
Hi Mr. Resolume,
Want to ask about some features that could be useful for programming.
1) Copying/pasting entire column with clips on empty columns or existing column (not only duplicate it)
2) Group slices when using it with slice transform or slice delay. For example, if I have huge number of slices, in “show slices” tab would be useful to “group” slices in order to add huge number of slices to “slice transform” or “slice delay” faster. Now if I have for example 500 slices, sometimes I need to add just some of them (lets say 100 slices), I need to add it one by one that is very slow
Thank you 😀
Re: Feature requests
Copy/Paste the slices you want to use into a new screen and leave that screen set to virtual, then just drag the entire screen into your slice section of the FX.
For column copy/paste, click the first clip at the bottom or top, then hold shift and click the top or bottom clip then copy/paste.
Cristiaan80
Post by Cristiaan80 »
I am also hoping that a Grouping option wil be feasable in a near resolume version, because you just want to odd/even screens sometimes .... and at another time i just want everything, but the Booth screen (few exxamples).
Added it to a new screen is indeed a good workarround, but i sometimes want to play with slices within a visual group. I could be a real cool function when combining it with sJumper from KPT Hippo.
Like i have 20 slices ->
I can make a group even / uneven slices
I can add a group for all outside slices
I can Add a group for all slices but the DJ booth
