best codec 2023
Anna
best codec 2023
Post by Anna »
Hello, I need a good codec for LED screens (p2). I render animations from After Effects and they lose the smoothness of movement on the LED. I care about maximum file quality.
Currently renders in H.265.
What codec do you recommend?
Thank you in advance for your help
vejas
Re: best codec 2023
Post by vejas »
assuming your playing it with resolume: dxv
otherwise hap (which is tricky to export from mac with silicon, you have to open after effects with rosetta and you will manage to do it)
animation or pro res are also a good choice (but it depends of the media server)
