Multi GPU - Render load / PCI Lanes question.
eretron
Post by eretron »
Hello world,
just a quick check up. In an instance where 2 GPUs are used, is the case still that the one GPU that is driving the Arena User Interface is the one thats doing all the heavy work (rendering) while the other is just used for additional outputs?
Also since in multi GPU setup with consumer grade CPU, with it's limit regarding PCI Lanes both GPUs will work in x8 instead in x16 PCI mode. How would that affect performance in real life Arena usage?
GPUs are Quadro RTX A5000 and Quadro RTX A4000
