Selection in middle of the screen does not work (Avenue on Mac)
blondedjosie
Post by blondedjosie »
Hi! When I try to select something in the center of my screen while using Avenue, nothing reacts. This happens whether it is windowed or fullscreen, and whether I use an external output display or not. When I use another application with Avenue running but minimized, it wont let me use the middle of the application either. Mac OSX signals that it thinks I'm using Avenue by the top toolbar.
Let me know if you have any leads on how to fix this! I can't use my bpm or layer one tools because of it. Thanks!
Re: Selection in middle of the screen does not work (Avenue on Mac)
If you move the Resolume window a bit, does the unresponsive area move with it?
blondedjosie
It does not. The window will shift, and the area will become clickable when no longer in center of screen.
Does the clicking also not work on other applications at that area?
How about after a system restart?
blondedjosie
yes, but only when resolume is open.
that did not affect it
Do you have windowed output enabled?
