Arena steeling focus
laeventsolutions
Post by laeventsolutions »
Hey guys,
If I load Arena while having other windows or programs open, if I command tab away or click away, when i click the window or program, Arena steels the focus back. So for example, I want to tab to another program like MagicQ, and it switches to that program and shows on the top bar I have focus with magicq.... If i click anything in magicq, it then changes the top bar to Arena. This happens to all windows and programs.
I use Advanced output and running Apple Mac pro, 14-inch, 2021, M1, 16GB ram. Ventura 13.0.
Any help would be really appreciated.
Adam
Re: Arena steeling focus
Are you running an external display with Resolume output enabled?
How does your Arena layout look like?
laeventsolutions
running output to built in hdmi straight to video processor, to led screen panels.
Just using the standard layout as it first installs, literally added 10 stills/png and applied some background effects.
I've used normal output and advanced output. Can't seem to find anything that stops it from happening.
Any other applications which might be affected besides Resolume?
laeventsolutions
None at all, it's only resolume that does this.
