REST API - retrieve name clip in autopilot
Timoxy
Post by Timoxy »
Hi all,
For an escape game i need to retrieve the name by API, i can get the name of each clip when i click on it, but when i activate the autopilot i can't get the name of the clip playing. If i click on the first clip it's ok the name appears, but when the clip is finished and play the next clip i've nothing, just the first name clip but not the second...
Have you got a solution ? Maybe it's better to use osc ?
edwin
Re: REST API - retrieve name clip in autopilot
Post by edwin »
You should be able to check loop over the 'connected' state of all clips and find the ones that are currently playing.
