Play next Clip with timecode
Hello there :) ,
I'm currently testing for an upcoming show. We'll be using timecode for the opening and for some show parts. In one part, we want to show a camera multiple times at different points in the song, in sync with the beat. I thought it would be straightforward if I put multiple Capture Sources on one layer side by side in the clip deck, adjust the offsets and durations accordingly, and set the autopilot to "play next clip." However, it doesn't seem to be working. Should this approach work? So, do I really need to layer them vertically?
Or, what would be event better, if someone has a better idea...
Best wishes
Re: Play next Clip with timecode
Play the audio from a Pioneer or Denon deck, and an use Pioneer/Denon sync with the clips, and offsets to launch them automatically.
Your approach should work, I would just leave the sources active in their own respected layers and just toggle layer opacity if it was me :)
I'll try.. thanks
