Resolume crashes while using internet toggles (tripmode/little snitch)
pepijn
Post by pepijn »
Often when I'm playing somewhere, the local wifi isn't very optimal so I'm using a hotspot.
Usually when using a hotspot, I'm using an app like Tripmode or Little Snitch to keep my internet usage under control (like turning off iCloud and Dropbox syncing but still being able to browse or download VJ assets.). I have it setup that whenever I use a hotspot, Tripmode activates and blocks these data hoarders automatically.
The problem is that since a while now Resolume doesn't like these applications and blatantly crashes when Tripmode turns on, or crashes during startup while Tripmode is running. This is annoying as it is, but even more so when I switch to my hotspot during a live set and Resolume crashes, ruining the evening (at least for me).
So my main question is: why? And even more important: Will this be fixed?
Thanks! Pepijn
Re: Resolume crashes while using internet toggles (tripmode/little snitch)
Could you please use the crash reporter dialog that pops up after the crash to submit a crash report?
That way we get lot more detailed information about what went wrong exactly.
Don't forget to fill out your email address, so we know it came from you ;)
