Batch Renaming Clips
ceecrb1
Post by ceecrb1 »
Wouldnt mind if I could highlight a collection of clips, say in one layer and right click, rename and it would take the text you input and auto number them.
For an example, highlight some empty clips, set "ignore column trigger" to a different value and it will populate with clip 1, clip 2, clip 3 etc.
Imagine I can do the same, highlight and rename "block A" and would auto get:
Block A 1, Block A 2, Block A 3, etc etc
