I figured out a strange behavior with the default transport. I used to play most clips in bpmSync, and set this as the default for video in preferences. Now when i insert a new clip in the deck it uses timeline as transport. when i clear the slot and reinsert the same clip in the same slot it uses bpmSync.
I use newest Arena version
https://youtu.be/uyeno_pd0MI
default video clip transport only works on second clip insert
Re: default video clip transport only works on second clip insert
Ok, got the message in the slack channel, that it is an bug with an already assigned ticket on it.
