is it possible
james res
is it possible
Post by james res »
is it possible to import midi mapping from resolume 2.0 to 2.3 ?
is it posible to export deck , and save only used video files within deck file plus deck file to CDrom , to backup easly ?
edwin
Post by edwin »
Hi James res,
It is not possible to import midi mapping from resolume 2.0 to 2.3 !
We made sure that you can import the midi mapping from version 2.3 in higher versions. So the next release will be able to import the midi settings from 2.3.
It is not possible to export a deck. Currently the deck files are in binary format and not editable, we hope we can change this in future releases so that it will be easy to edit and made more suitable for backup purposes.
Cheers,
Edwin
