Change slider start/end points
JBroadway
Post by JBroadway »
I'd like to change the start/end points of the rotation z slider so that it starts at -360 and ends at 360 degrees so when I slide it loops multiple times.
Is there a way to do this is Arena? Or will I need to make a custom patch with Resolume Wire?
Interestingly I noticed you can double click to edit the slider values, however, trying to type a number above/below the default ranges (like 360 degrees) has no effect and will just reset back to the default 180 degrees.
Any help is much appreciated.
Re: Change slider start/end points
Changing the slider ranges is not possible currently.
-360 -> 360 would be two full rotations, right?
Do you want to rotate manually?
A custom Wire patch could do it for you where you could multiply the rotations.
--begin-wire-patch--
1112.3ocyXszaiaCD9uRgNKFPQIJKka1xN.6gtKPwBzCEAEzRz1rkVzUhxaxFj+6cHork7iHqcaVzMGhon+lgyiuYFJ+hWtprjmqEpxZu6+iW7VUo1BKv9dpF8tFs2i9dZErSfumnztwq9GgEb.F9HNx0vEdg5hZggOAWzk5CNhJklYrvSfReSUF.3drc8mpJ3UV+IzmBatkqYd2+hGqQuQAegmmuWNSyWqpd169xFoz2qfuSpddKuT+YV0Zt1feYEqLeCfexcAI2gAoJYa4vy+tnhCOsmWUarP.5V1eYz7D3vDklUAfotioMhie8Ui9qyqD6rdj0.JD06jrm+nSivFhB3vEqDFS2KOOfEurfhBISnnHdT.hw3wnhD1RVbRXAgU.xHE47xZ9CBYqRZ2nSqaYBoakpRrVTxjuS9Wxo92+zvjBMDNCIIzXH8wqUxFcq3a3h0afyL.m.jruHJzfbAoDLHYMaO+GiMo2zrcY4w.PSU6h87xBGO..UxeR+QUA+CEd2C1cIrr1ncrkwn0UhkMZ2VqjpuX9T+7NiEYeDzFS1XdrVrFhtFUJJq0fW3DpErnD3aPp8H9.iEtT0TVT2OBkP5hOgPr5ISbBH4PjkDRAQxkrZqDhBSTZRb5DRLEMiLkfhxBxPIYQYHRZ.c9jjrrjEo8iZAVMnx+aP18.iSYJETRazXE7WLCisaYcAs6frU1cthFhXMUbRQmyXpgL9yFQAvhgRudw.eWf5wiYxO6j+W9PoWubzetWTKVZ3w5pFNnqfKS.FpgpB4riN6w7QWd.NMllXxCiOeAN3MzZmSO9DbWSrwXxFEWmyj7Q6eZnVoVN5C.j4pTNKO6XMI0x4nINNWHM7s4boDBzaBiSQoyIyQzGRRA5VTVVXXeNG46fy4xzml7LdvQWBZtie7PtaDjydCTNSoc.wGx.CctA9AOdZr+lV4IEFsrv90G83eWIodNK5DVh+I0D8pwLZYkpZ6fkXjKKwd25cQr7nj3XGOJLdfdWKVLEEMOLAkrXAEgWLaZT1r43oKV7+buqKaZ8oF8fgzvu+wFaX0nsrm5AcoRI6f1dBVXhxaAaz8nN8HOuj3NyLmSOtyffbXT161TixAZgdnyzTk0TJtIFfI0dmf2F0XGglj5XgwCLAcNLeEEMMdJZVbb.BSlNaAklMg7vC8YgguCrvK56L7nytbtKUzQUbYuyC9GicsA5NV7ucnG3PT3n+K27wbMdTg.tHcs60KFl74t692f.0huxGBiYXi46viXZqY+fah6lbr1QlgD2HynjAFYNEOOAEQRmhlRoIn3zYYzj434QD56RqN7ayx5B2Cg4Zyprw7Cg0qkjODJuV9ri78qMRsXm74AIezeb8OWwj0ioA5AbitC5O0s9RwVVIkD8yXqufugVecM8Fa6tQv3d08ppMUt7rIAILlaNngJ6uZ.DCcgP3+eUY9YHr8g3R2ufhwrM0tQdlg+lWaw2yDEHdvE+9WPa2SxD
--end-wire-patch--
JBroadway
Post by JBroadway »
Zoltán wrote: Fri Dec 08, 2023 10:47 Changing the slider ranges is not possible currently.
--end-wire-patch--
Ahh I figured I'd probably have to use Wire. Thanks for this.
