Hi there,
I am currently trying to figure out how I can get the filter of my prophet 6 from sequenctial to automate an effect in resolume, since the prophet 6 is based on NRPN midi messaging I am trying to use a max for live device Nrpn2 in ableton to receive the Nrpn messages from the filter and then I could map it to a macro or even a multi map device in ableton. Now the next step would be to get this inside resolume, but I cannot seem to figure this out up until now. Looking forward to hearing your takes on this!
Thanks,
Jim
how can I receive ableton automation into resolume avenue? I am talking about the parameters.
Re: how can I receive ableton automation into resolume avenue? I am talking about the parameters.
I forgot to mention, I already tried directly from the prophet 6 to resolume, but the range is limit to 1 parameter, so it does not work. like it goes from 0 to 1 and not 100 or so
So you already managed to map the parameters onto macros?
I think the easiest way should be the Parameter Forwarder from here:
https://www.showsync.com/tools
It's included in the Resolume M4L Patches download
- Bassindaniel
