Feedback Source Losing Saturation Per Frame
I had to reinstall Windows 11 to fix UI bugs I was having and after I repopulated my Resolume file with all my videos I tested the feedback layer and it was losing saturation as it went while my other computer (top monitor) dosent lose saturation which is what I want. Can anyone please help me figure out why this is happening. The settings are identical the versions are identical I cant see why this is happening. Thanks
Re: Feedback Source Losing Saturation Per Frame
You have effects on the feedback clips, maybe they are set differently.
Also one of the compositions is paused. That can change how stuff looks with BPM animated parameters.
Everything is synced to timeline the pause has no effect.
