dll files
james res
dll files
Post by james res »
what are cv096.dll MSVRC71.dll files used in resolume for ?
when I reinstalled resolume and copied deck and plugins directly to
plugin and deck folder resolume starts with these missing files ...
will they influence how resolume works ?
[Edited on 30-3-2006 by james res]
alchemist
Post by alchemist »
HI,
you probably need to reinstall vv... (dont remember name exactly) plugins - the dlls are required by those AFAIR.
And try to do a search on forum before you post - I had the same problem and found solution here.
james res
Post by james res »
vvarp :)
pluings from poland ;)
