Triggering Videos on Resolume Via Arduino using a PIR Sensor
oto.og
Post by oto.og »
Hi, I'm desperately trying to find a solution for triggering videos on Resolume Via Arduino using a PIR Sensor; sending and OSC command to resolume once the sensor state changes.
Tried to find solutions online but couldn't land anything concrete :cry:
Pls helppp
tijnisfijn
Re: Triggering Videos on Resolume Via Arduino using a PIR Sensor
Post by tijnisfijn »
Can you please give us some more information how far did you get? What are the problems that you were running into? What is the different software that you're using or tried already?
oto.og
Post by oto.og »
tijnisfijn wrote: Fri Jan 26, 2024 12:46 Can you please give us some more information how far did you get? What are the problems that you were running into? What is the different software that you're using or tried already?
So I tried following the below methods but couldn't really get anywhere. It would be helpful if there's something from the bottom up which I could build on.
viewtopic.php?t=13265
https://forum.arduino.cc/t/arduino-pir- ... deo/511004
https://forum.arduino.cc/t/arduino-resolume/357392
With Pi, you can use node.red and send out OSC. I'm sure arduino wouldn't require too much more work.
oto.og
Post by oto.og »
UPDATE:
So I can read the output of PIR Sensor from Arduino IDE to Processing IDE.
I can also send OSC Commands from Processing to Resolume.
Now my only obstacle is sending OSC commands upon the condition of the PIR Sensor giving "HIGH" when it detects motion.
