Running hot on idle
LaserLuke
Running hot on idle
Post by LaserLuke »
My ram and vram are idling high in arena.
Specs:
Windows 10
32gb ram
rtx 2060 graphics
Arena 7.18.2
cpu is sitting around 10%
ram is sitting around 85%
vram is sitting around 73%
*with a new project, while nothing is playing
Any and all suggestions welcome :D
Re: Running hot on idle
That seems abnormal. Can you click on "Show Display Info" under the output contextual menu at the top and let us know what GPU is rendering Resolume?
LaserLuke
Post by LaserLuke »
yes, says it's using the rtx card, see attached screen grab
thanks
When running, could you open the task manager and snag a few photos of the applications running sorted by Memory, another one sorted by CPU and another one sorted by GPU, then go to the performance tab and snag the same 3 photos on each of the 3 different parts of the machine? Thanks :)
LaserLuke
Post by LaserLuke »
yep!
LaserLuke
Post by LaserLuke »
and
LaserLuke
Post by LaserLuke »
also just noticing this machine has only 16gb of ram, not 32 which i was assuming. 16gb is crazy.... :o
