Teaching and 2 machines
joebataz
Post by joebataz »
I just renewed my license although not for educational because I haven't received my credentials yet.
The bigger issue is that I do my lesson plans on my iMac at home and then transfer them to my MacBook Air for school along with media I will be using for the class.
Do I need a second license for my MacBook Air or can I use my license on both machines since they WON'T be used at the same time?
Also my MacBook Air has Apple Silicon. Will the current version of Avenue work on M2 chips?
Thanks,
Joe B
Christoph
Re: Teaching and 2 machines
Post by Christoph »
You can use the backup seat for your second machine:
https://resolume.com/support/en/registering#1-backup
And yes, Resolume has native support for Apple Silicon processors.
