freechain freeframe trouble
zwick
Post by zwick »
I have tried Pete´s freechain and i got different useless results.
Sometimes all parameters indicated foo,another time i got no parameter at all. Even with a simple test with just some of petes own plugins 'recompiled'.
Maybe i am to tired a the moment and i`ve overlooked something simple but crucial.
Somebody who can give me a hint?
It would be an great advancement to have something like freechain functioning inside of resolume
zwick
mfo
Post by mfo »
Freechain does work!
Sometimes the parameters show "foo", but they do work.
Another problematic bug (or is it a feature?) is when you (coincidentally) use a plugin-ID that is already used by a different plugin. Then Resolume sometimes crashes or is not working correctly. Try to alter you plugin ID. It can be found in the properties dialog.
Initially Freechain gives you the always the same ID, you must choose your own!
zwick
Post by zwick »
Thanks a lot,thats it.
Foo is not a big proplem, because it still works.
The ID thing was the reason.
Now its prefect!
