cannot get a transition to work
camilozkk
Post by camilozkk »
Hi!
I dont know why, but I am getting a fade in (fade from black) while creating a transition between two clips. It is actually the same clip, copied in column 1 and 2
I have tried different things and I cannot get it right. Changed the transition time, changed the transition blend mode, changed the beginning and end of the clip, the play mode, and the timeline speed.
If I triggered the next clip in the layer transition control, it works correctly, but if I leave it running on itself, I always get this fade in. I would really love to know what am I doing wrong....
help please?
https://youtu.be/Oa96yyxrEvc
Blusound
Re: cannot get a transition to work
Post by Blusound »
In clip Transport you have the "Play once & clear" selected so the first clip reaches the end then clear. After that the player starts to play the second clip from the beginning with the transition you have selected. It's a normal behavior.
