anyone help if you pleas
blancior
Post by blancior »
Does anyone knows how to configure audio source. I`m playing music from win amp and I can`t get any sound in resolum. Are there any configuration needed etc.
Thanks for response
Blant
from our manual:
http://www.resolume.com/support/manual-2-2/index.html
For the audio analyser in Resolume to work properly you need to have your audiodevce and volumes setup correctly. To do this open the 'Sounds and Audio Devices' in the Control Panel. then on the Audio tab select the correct default device for sound recording. Then click on the 'Volume..' button to set the volumes of the recording device. Now select the source for the audio that you want resolume to analyse and set it,s volume to maximum. If you do not know what source you need or you need multiple sources then it's safe to just select 'Stereo Mix' and set that volume to maximum.
