Still waiting...
Synner
Still waiting...
Post by Synner »
Hello,
I just wanted to know the actual date I can expect to get the configuration software that was promised for the React?
There are many tweaks I would like to make - to enable me to do what I really want with this controller. Software please. It was promised a long long time ago...
Synner
edwin
Post by edwin »
Hi Synner,
you are right, i will try to see what's taking them so long.
I will let you know when i get the answer from the developers.
Cheers
Edwin
DrMazoola
Post by DrMazoola »
Edwin -
Any chance to check with Netzteil, yet?
Maz
nowig
Post by nowig »
should be so usefull...
nowig
edwin
Post by edwin »
Hi All,
i did check with Netzteil, but they have't responded top my questions.
We will give them a call this week. To put some preasure on it.
sorry about this, hopefully they will give us some more info soon.
Cheers
Edwin
Synner
Thanks...
Post by Synner »
Thanks Edwind for taking the time to call them.
I know I'm an early adoptor of some products and as such I go through the settling in period... But I now need the config software!!
As a side note - I am also using a www.jazzmutant.com Lemur which is endlessly configurable!! Thus you can feel my frustration when I really only need to tweak the React! I've long since conformed to the defined Layout...!!!
Will look forwad to their response.
Synner
The firmware updater is nearly finished, aswell as V3 of the controller firmware, it will be available later this month. And by the end of next month the configuration tool will be available.
Synner
Post by Synner »
Really??!!
Synner
OK - I am patient but...
Post by Synner »
I'm still waiting for the updates and the controller config software that was promised to me in "only two more weeks..." - that was back in January when I got my React...
7 months is not two weeks...
Synner
nowig
Post by nowig »
we still waiting:(
Vj NoWig
The visual Brothers
