Mapping, DMX and Decks
elbundlo
Post by elbundlo »
Hi there,
Has anyone found a good way to use DMX mapping for Decks?
I know it's easy to map them with Midi - just assign to a button on your APC mini or what have you.
I'm using a ChamSys, and found the deck selection in Media/FX.
I'm thinking that the obvious way to store decks would be under the 'beam' palettes, but can't think of a way to achieve this.
Any suggestions?
Cheers,
Paddy
Re: Mapping, DMX and Decks
You can assign each deck a DMX address just like you do with MIDI, or for use with a single address or encoder would to be to map the |< >| buttons next to the deck with a DMX address, then assign your deck UI in your console to that specific address.
elbundlo
Post by elbundlo »
Ok, thanks for the advice!
I'll give this a go in a week when I get back home...
