Operating System: XP Home
Processor: AMD athlon 2500
Videocard: ATI 9200 Mobility
Files type: N/A
Codec: N/A
Hi i put resolume into fullscreen on main monitor by accident and now it always loads in fullscreen and i cant seem to disable this from happening or see anything but a black screen.
I got a VJ set tomorrow and need help ASAP!
Sry if this has been posted b4 but didnt see a forum search anywhere.
Thx
Stuck in fullscreen!
Spectorial
Anonymous
The search function works!!
Thanks, this was the exact same jam I just got myself into. Your magic key combo fixed mine as well.
I'm not exactly sure this is the right place to put this post but I saw, while assingning midi controllers, that there was a fade interface option. I would have like to see that kind of fade option for the output window. It could be usefull to fade out the output, set things up in the interface and then fade in the output. Or maybe just allowing the interface to remain "on top" of the output and then be able to fade it out so I could use the output in fullscreen mode.
