[?] NDI 6 Update
samirbridi
[?] NDI 6 Update
Post by samirbridi »
Hello,
Is there any possibility of updating NDI resources in Arena?
I ask because today NDI 6 is already using the H265 and GPU resources instead of the CPU. This can be of great help for those who use it a lot and also start to have more compatibility and fewer failures.
I notice that when using NDI, the CPU processing resource increases greatly.
It cost!
niceolum
Re: [?] NDI 6 Update
Post by niceolum »
For Win
1. Win+R -> cmd -> Enter
In CMD window type "winget install --exact --silent --id NDI.NDIRuntime" and press "Enter"
or
Download and install NDI 6 Runtime manually
https://downloads.ndi.tv/SDK/NDI_SDK/ND ... untime.exe
2. Go path "C:\Program Files\NDI\NDI 6 Runtime\v6\" and copy dll "Processing.NDI.Lib.x64.dll"
3. Go path "C:\Program Files\Resolume Arena\" (and if you need "C:\Program Files\Resolume Wire\"), rename original dll "Processing.NDI.Lib.x64.dll" for example to "Processing.NDI.Lib.x64.dll.bk" and paste NDI 6 Runtime dll from clipboard
Now your Resolume uses NDI 6
niceolum
Post by niceolum »
Same for NDI 6 Tools
"winget install --exact --silent --id NDI.NDITools"
"https://downloads.ndi.tv/Tools/NDI%206%20Tools.exe"
"C:\Program Files\NDI\NDI 6 Tools\"
Just because the libraries and dependencies are there doesn't mean the software will use those features. I would advise against doing this, as changing anything from vanilla install will not get you any official support.
edwin
Post by edwin »
Next version (7.21) will have the NDI 6 update.
