More default options
Grimm90
Post by Grimm90 »
Hi , ive often find myself wishing for more options in the defaults tab of the preferences panel of Resolume Arena...
For example if i change a static parameter of an effect (the cogwheel) , lets say to BPM sync, it will always defaults to 4 beats and loop mode.
This is one setting for example i would prefer at ping pong mode and 1 beat.
This could also be extended to other items im sure other users also can chip in here.
For example the default layer transition blending mode. You can already set the default layer blending mode, why not also for the transition ?
Also wouldnt mind always having an enveloppe enabled by default with a default curve on the enveloppe if i select a parameter 'activator' like bpm sync
I do think it's positive that it's these kind of features now that are popping up in me when playing with Resolume and not the massive stuff like the undo button or the layers / group collapse , great job so far on improving this software <3 :D
Re: More default options
ya.... grimm good call. More default options!
