Razer Ripsaw HD - does it work with resolume
xewinga
Post by xewinga »
Hi everyone
please tell me if you that Razer Ripsaw HD works as a capture card in resolume.
THanks
Re: Razer Ripsaw HD - does it work with resolume
IDK, You could test it and report back if it does or doesn't work.
You could also save yourself a LOT of money and just grab one of these: https://www.amazon.com/BlueAVS-Capture- ... B08QF6YWWD
I'm 100% for Razer Laptops (own over 25), Mice, & Keyboards, but other peripherals are usually just overpriced 'average' gear at best.
