Hi
I am a complete beginner when it comes to flash, therefore I am unable to create any sound reactive flash files for resolume.
Are there any places where you can download some - have people uploaded a bunch anywhere. I tried searching on the forums, but i couldn't find anything.
Thanks in advance
roop
Resolume sound reactive flash files resources
hi prupert,
if you install resolume then a few flash flash examples are put in resolume's demofootage folder. Check out the bars.fla (bars.swf) file for an audio fft example.
Check out the flashparams.fla file to see how you can use the flash parameters that you can send to resolume. Right click a channel in resolume wich contains a flash movie to and you will see a tab called variables, on this tab you so some sliders (the same as for an effect) wich are called rparameter1 to rparameter4.
check out this section in the manual for all the names of the variables that are available through flash:
http://www.resolume.com/support/manual- ... oc78124843
the audio fft repsonsiveness wull be much improved in resolume 2.4
just to let you know.
Cheers
Edwin
Cheers
Edwin
Try this for downloadin some flash http://www.flxer.net/
thanks, I've already stumbled across flxer - but what i am really after is flash files that will make use of resolume's FFT sound analysis jiggery pockery - since I can't write flash files myself i was hoping there was somewhere you could get hold of some, other than the 10 odd files that came with v2.0 - oh well, maybe i should learn to code flash...
thanks all the same
thanks all the same
