only 1 effekt paramter
sinistersnipe
Post by sinistersnipe »
hello, first post :)
i have been working very well with resolume version2.3 until recently and error occured while i was assigning new keaboard shortcuts. Since then resolume only displays one effekt paramter, the top one, for each effekt.
I have a ATI Radeon 9700 Pro 64mb graphics card, Pentium 4 3,4 ghz HT, 1024 Mb Ram, Windows XP service pack 2.
if there is no other solution i would re-instal resolume however i spent a lot of time costomizing it and i wander if there is a way to save my keaboard shurtcuts / decks.
thanks beforehand, sinsitersnipe
lichterloh
Post by lichterloh »
huhuu ;)
if nobody comes up with any solution, here's how to save your settings:
decks are saved to the directory 'decks'- wherever you installed resolume to.
as far as i can see are keyboard-shortcuts saved to the file 'preferences.xml', directory: 'settings'.
just save these somewhere else before uninstalling resolume and then move it to the right directory again after reinstalling.
your midi-settings can be saved wherever you want it to (and loaded from there). you can do this in resolume ->preferences->midi general.
sinistersnipe
thnx lichterloh, anyone else?
BuckRogers
Post by BuckRogers »
Hi sinistersnipe, I have the same problem here since a while. Also an ATI radeon 9700 and SP2. I'm also not looking forward of re-installing, since I have had a lot of time spent in programming effects in Resolume for my midi controller....
So, anyone fixed this problem? Or is it a known issue?
