Increase Max Lumiverse Framerate
I am using fixtures that directly receive Artnet without using DMX, and they support framerates above 40fps. It would be great if I could output Artnet at least up to 60 fps, or ideally to whatever rate the composition is running at.
Re: Increase Max Lumiverse Framerate
Artnet=DMX
DMX frame rate cap is 44Hz (About 22ms)
This is a standard of the protocol, so I guess you would need to request this with Artistic Licence and not Resolume
Not all Art-Net is destined for DMX.
From the Art-Net v1.4 specification:
The ArtPollReply-RefreshRate defines the maximum refresh rate that a gateway can
accept ArtDmx packets. For a gateway outputting DMX512, this will always be the
maximum rate of 44Hz.
However, non-DMX512 gateways can declare a higher framerate limit.
I wouldn't hold my breath on this ever happening. Just trying to set realistic expectations for ya
At the very least I'd like my additional 4Hz, but I would love to keep everything sync'd at my composition framerate!
