Is there a way to disable triggering other columns unless a specific clip/column is playing?  A summary of what I want to do:
Have a video looping on column 1 with other clips that play once in columns 2 and 3 then go back to the main loop on column 1.  When the main column 1 loop is playing I want to be able to trigger either column 2 or 3, but if column 2 or 3 is playing after being triggered, I don't want Resolume to be able to respond to any column triggers until it the clips finishes playing and it goes back to the column 1 loop.
