Full show export
ceecrb1
Full show export
Post by ceecrb1 »
I use the media manager to collect media a lot, when creating backups and also for long term storage of past shows I may need to refer back to in the future.
This only stores media and layout of clips.
Can we have a tick box which can also export all currently active config files, for example, advanced outputs, OSC, Keyboard & DMX shortcuts etc etc that would make it a true, full backup of the entire show and system state (even if it's just all kept in the folder and needs manually distributing in the documents/arena folder etc)
If they were stored in the base folder along side the Media folder, with the final folder structure of the mydocs/arena/ folder, it would just be a simple case of copying that whole lot in one move.
