I have a lot of different output needs - sometimes it is as simple as a single 16:9 video screen, and sometimes it is multiple screens with a bunch of DMX mapping. Currently, the Advanced Output window is global to Resolume, not specific to the show file that is open. You can save and load presets, but these are not tied to the project so it's easy to get lost quickly (which versioned preset goes with which versioned show file?) It would be great if we could tie a preset to a show file, so that loading one loads the other, to make sure that there are no mistakes.
Also, related, in first testing the presets I accidentally deleted everything using the "remove" instead of the "new" option, thank god for the "cancel" instead of "save and close" option, it would have taken a lot of work to figure out all my DMX patches again...
Advanced Output - set per project not as a global?
Re: Advanced Output - set per project not as a global?
My trick for your problem: call the advanced output preset the same name as the composition. This way you don´t get lost
