For a show, I have to manage many manipulations, in light, sound, manipulations of accessories and sets, in addition to the video... for this to be possible, I have to use many columns to trigger synchronized clips.
It works very well!
But for 2 days with young people that I train at the show (fortunately on another project)
The triggering of the Resolume bug columns totally, without me finding the reason.
When I trigger column 1, resolume triggers column 1 and selects column 2.
When I trigger column 2, resolume triggers column 1
When I trigger column 3, resolume triggers column 2
When I trigger column 4 and after, it seems ok.
This is the first time that it happens to me, but it can really have serious problems!!
Can a false manipulation change the behavior of resolume on the first 3 columns? Can you guide me to check the triggering behaviors?
In addition, just before I installed an old Behringer F610 sound card with its USB driver.
At the installation, Nahimic service was embalming (whereas I thought I had already suprised!)
So I deactivated this service.
There were also column triggering tests at noon, with a Novation launch control XL button, on the next column button, but it was cleaned up and even without the midi controller, ca bug!
It’s the only change I can imagine, from the time everything went well to the bugs.
Currently, I use resolume arena 7.21.0 rev37521
I hope you will enlighten me and help me solve my problem.
I love resolume, but now I’m freaking out!
I hope it’s not a greedy Gremlins who will devour everything.
Column trigger bug, or Gremlins VJ ?
tijnisfijn
- Team Resolume
Re: Column trigger bug, or Gremlins VJ ?
I am really sorry this screwed with your show. We just have a hot fix 7.21.2 out today that should solve this issue..
Please let us know if this solves your problem or if you're still encounter it after the update.
guillaume bertrand
Indeed, I noticed this problem with the version I use and not before!
I will install the new resolume and test again.
I will come back to you if it works and also ask for help if it is not enough.
cordially
cordially
guillaume bertrand
Great!!! Wow!!
Thanks for the responsiveness and availability.
The update seems to have simply solved my problem and everything seems to be stable again.
I will no longer seem to do weird things with Resolume in front of my students!!
Thank you very much
Thank you very much
