Hi people
I have a problem when i am working with decks. I have a lot of clips so i need to put them in decks, this seems to work fine when i am using only avi or other video files. But when I insert a sequense of bitmap files and also with other formats, all the decks containing sequenses are messed up. Pictures from different decks are loaded in other decks and sometimes the program crashes. I am using resolume 1.1 beta 2, is this problem fixed in a later version? I hope so cause it is a super program, but I need the decks.
Messed up decks
Mills_
Wahne_
komart_
wesmundo_
While you're working on decks, how about allowing multiple decks to be loaded into memory?
We could use new clips without losing the previous ones, mixing across multiple decks, with potentially all your clips on hand at once! (perhaps with a configurable limit on 'pages' to suit available RAM).
This was suggested by MJS & stark before, but it's that good.
They suggested using tabs, but perhaps the browser/generators menu space would be better - less change to the GUI and more space for decks
Highlighting decks in the list that have active clips would be good too.
