in/out points for opacity control
resync possibility when synced to bpm clock
random play mode according to bpm
file name display
resolume rocks!
2.4
lichterloh
yeah, would be great as well........
something weird we thought of, which maybe isn't possible anyway: if working in vidnet mode it would be awesome to have both mice controlling both laptops via lan, meaning that mouse coordinates are cropped at the output monitor and sent to the other laptop. but right know i recognize that this wouldn't make sense as long as you can't display 2 separate mice, which i guess is the greater problem than the coordinates, huh? anyway, still dreaming......
show 8 beats instead of 4: i know this actually doesn't matter, but we think it comes in handy for example when you want to use channel switch set to one bar and we believe it would then be easier to adjust the bpm right.........
would be great if the bpm light bouncing would always be visible- to control and resync it's great where it is (as you can do this via midi), but we'd like to be able to see easily if the bpm are still right even if we are browsing decks for example- if it's to us you could even stretch the bpm light to full screen and put it on the bottom (top, whatever)- can't be visible enough.......
great software, lots of respect.....
