Hello.
does anyone else find it useful to limit the opacity faders?
i mean, when i sync the layers opacity fader to BPM I'd like to have the option to limit it 99% MAX instead of 100% if i use LumaKey for example.
other thing is the fact that i can't use 1 footage in 2 channels at the same time.
It's possible to do that if I take the same footage from other deck but it's kind of restricting.
thanks.
Emendi.
Question...
To answer your second question about putting same clip in 2 channels - you can, but the way resolume is set up, each clip on deck can only be used in one channel at a time - however you can load multiple instances of the same clip into a deck and use the different instances. This even makes it useful if you want different effects on the same clip...
