It should (I think...) be possible to play BPM enabled clips at the clips default framerate.
So that if the external clock stops for some reason - you can still play the clips.
Steen
syncopated.tv
BPM enabled clips
Hi sj1972,
the guys from Eyesupply pointed us out that when the midiclock stops all clips come to a halt. So for the final version we build in an option that if the midi clock stops, Resolume will swith to manual bpm mode (if the option is checked) in the same tempo as the clock was running.
Cheers
Edwin
Cheers
Edwin
