Help wanted.
I recordet my visuals and now i can not oben the avi file with the windows media player. In the manuell it says the format is: raw uncompressd.
But i cannt edit it with any programm.
Can anyone help me please.
recording
LudikaStyle
It's probably larger than 1GB. Try opening it with VirtualDub, it's freely downloadable from http://www.virtualdub.org .
It works and you can even transcode to another codec (format) if you need further editing in another software.
