Effects only being applied to first layer in a group?
rayg006
Post by rayg006 »
Hi Guys, I'm wondering if this is a thing or not.
I've got a group with three layers in it, all layers have different mappings in Stageflow to portions of the
screen but want to do a transform effect for each layer triggered by the same midi key.
The problem being the effect is only being applied to only the top layer in the group, if you swap the order of each individual layer to the highest (top layer) in the group they all work individually as expected but the middle and lowest layers never work whilst in a group and the desired effect cant be applied to the group it needs to be on a layer level.
Seems like a bug to me?
Currently running 7.21.3 rev 38686
Re: Effects only being applied to first layer in a group?
You will need to create a mapping for each layer and select the mapping type to position or this layer.
Or
Create 1 mapping for selected layer and just select a layer before using that mapping. (How I work)
