I'm sure this already exists as a wire effect or juicebar product. I was wondering if there is anything out there that can use a color effect with adding colors to its nearest hue. For example If my main color is set to amber it would add small amount of reds and yellows perhaps based on luminance?
thanks!
More dynamic colorize
- rawdesigns
Re: More dynamic colorize
If you'd want to make such a patch, Analogous Colors could be of help
- rawdesigns
thank you! I'm very novice at Wire. Trying to use that sample you sent and have a palette to choose from the following
Red, Amber, Yellow, Green, Cyan, Blue, Magenta, Pink, White
Well, it kinda depends on how wou want to apply the different colors
Try to do multiple colorize effects frem the texture input with the colors, then use compare nodes like Within from the original input. That would give you a result you could use as mask, for the colorize results, and then you could mix the results with a video mixer.
Like the Recolor effect in Arena?
We are also working on LUT-support at the moment, which might also solve this for you.
Full Spectrum
+1 for LUT support.
It is very interesting to know what things you are working on. Can you tell us about things other than LUT support. Thx in advance!MarkyMark wrote: Fri Oct 11, 2024 13:36 Like the Recolor effect in Arena?
