Bug Report
movebandit
Bug Report
Post by movebandit »
Now heres a little Buglist. Didnt had time on my last Job to start debugging mode, but next week im gonna try.
-BPM Pause mode then tapping ->BPM jumps up to 500 BPM
-shutdown is lasting veeeeery long...too long for a quick restart
-my deck with live capturing is empty after saving and reloading
-more than 2 of the new beatmappers in the layers makes output freeze
-deaster with effect categories...i spent a lot of time in sorting all my effects in 2.3. in 2.4 everything was gone. After trying to resort:
-standard effect categories always reload with standard name, no chance of deleting them. If i do, after restart they come back with only one effect inside.
-Space Bar is not realized by effect cat. renaming
-not more than 8-10 Cats possible. (Every Cat more is deleted automatically by restart)
-several times while loading decks/effects freeze and blinding white output on all screens
-Bypass button doesnt work anymore if one layer is routed directly to an output (in 2.3 it worked fine)
i think other and more detailed bugs gonna follow.
Greetz Maze
+ Confirmed
+ Can,t confirm this, it is indeed a bit slower then 2.3 but should not take ages, do you have a midi device connected?
+ Can't confirm this, what other items does your deck contain?
+ Can,t confirm this, 3 layers all in bpm mode and all 3 effects slots also with bpm parameter animation is working fine.
+ effect categories is a bit shaky indeed, can,t remove categories, can,t rename a newly created category
+ Some other people have reported this be but have not yet been able to reproduce it, we,ll keep trying ;-)
+ Confirmed
Thanks for you bugreport!
movebandit
-yes, i use a Evolution mk224 via usb for controlling
-I tried different "setups" normally i´ve got one "live"-Deck, with only Capture Card and several effects. But also it doesnt work with only one field. I´ll try how it works when i use mixed material and report again.
