Resolume cannot load from start
kevin
Post by kevin »
Hi all,
I having problem with new launching 7.21.3. It cannot load the example composition or any, I tried downgrade the older version but it only can work with 7.13.2. I even tried to re-install windows, swap SSD, install on difference hard disk but still same.
My system is: 2 CPU Xeon Silver 4114, RAM: 48GB ECC main SuperMicro X11DPG-QT, 2 x RTX2080Ti
Have anyone experience it or same problem before and can fixed it already?
I also attached capture screen of resolume. If need the log file, I can provide also.
Many thanks,
Christoph
Re: Resolume cannot load from start
Post by Christoph »
Does it change a thing if you select an audio output device in the preferences?
kevin
Post by kevin »
Hi Christoph,
I change the output audio out of "select" mode then it works now. Thank you so much.
