DMX Example file comment mistake
stanleystark
Post by stanleystark »
Hi, there seems to be an unimportant mistake on the DMX example flash file
its on the comments...
it says
//DMX values range from 1 to 512
//DMX channels range from 1 to 512
as far as I understand each DMX512 cable transmits up to 512 eight-bit values, between 0 and 255 ... so the value range should be from 0 to 255 and not 1 to 512 (that is only for channels)
edwin
Post by edwin »
hmmm... yes your right. I will fix the comments.
Thanx
Edwin
