1.51 version... quicktime problem?...
stealthsyst3ms
Post by stealthsyst3ms »
Hello everyone!
I've installed resolume onto my Laptop ( fugitsu 1437G ) but carn't get any of the quicktime files i've downloaded to work, the app seems to freeze or get very slow, when i select a mov. file in the browser......
wish i had sorted this lastyear....instead of getting stoned and staring at my mpegs on resolume for hours at a time!
great software though dudes.......just me being really shite on the computer me thinks
edwin
Post by edwin »
maybe you should check out the latest version, version 2.4.
The support for quicktime in 1.51 is not good.
But even in version 2.4 i recommend not using quicktime because the performance is much less then when using vfw .avi files.
Cheers
Edwin
stealthsyst3ms
Cheers
Edwin
ok cheers Edwin!
