Problem with putting clips into resolume
ramiroelliot
Post by ramiroelliot »
Ive downloaded a few videos from yt, converted them to dxv3 with alley,but after trying to import them into resolume only half of them show up(the rest shows the grey loading bar then dissapear) If i import them in the original mp4 format all of them work fine. Has anybody encountered this, or is it something really obvious that im missing?
Re: Problem with putting clips into resolume
The files might be damaged, try converting them with Alley.
