bcr2000/bcf2000
poki
bcr2000/bcf2000
Post by poki »
do you connect it to the laptop via usb or you use midi port?
VJ Nexus
Post by VJ Nexus »
both options work fine. It's a matter of how you have everything setup - ie using other midi gear etc...
poki
i\'m going for a secound hand bcr2000...
Post by poki »
what comes with the midi? cables? drivers? i'll appriciate a list of things that comes with the bcr2000
thanks
normal
Post by normal »
Just usb cable n power.
