full PAL beaming and resolume
Bas_
Post by Bas_ »
While vjing we use resolume and video tapes as well. So we have got a difference on the screens because the beaming surface of resolume is smaller than that from a videotape.
Is there a way to fix this? And don't say 'trash the tapes' cause a computer can crash...... :-(
ARGRTZ
jmode_
Post by jmode_ »
trash the tapes! ;-)))
have you tried to use a scan converter to make a PAL signal out of a fullscreen resolume signal? i usually use the TV-out function for resolume output and plug it into a videmixer, vhs tape on another channel. thats the way it works - otherwise you can use a cpture card and stream the vhs tape into resolume, so there is no need of mixing anymore
greets
jmode
chadd_
Post by chadd_ »
definetly trash the tapes.
heh heh.
it sounds like an underscan problem.
what vid card are you using? i am using a GeForce4 and i have the same underscan problem. the image on the screen is smaller than what gets projected deirctly from a DVD.
anyone able to help on this one?
Bas_
Post by Bas_ »
indeed chadd, its that underscan problem. I am using a Geforce 4 as well. Resolume works fine. But we always have to zoom the beamers to get a full screen projection, but then again we overbeam the screens.
We are trying to find a solution for this, but till now we don't have one.
Anyone?
wesmundo_
Post by wesmundo_ »
How about TVtool software?
http://tvtool.info/index_e.htm
I haven't tried it yet but it looks like it could solve the problem, though not on all machines judging by what little I've read of it.
komart_
Post by komart_ »
i got a solution for you,maybe you won't like it but i t works : sale your geforce and buy a matrox
Bas_
Post by Bas_ »
OK komart i will try the matrox one!!! It's all software,.... eeeeh matrox,......brother of matrix. Follow the brown rabbit eeeeekkk, lets hide.... before we get into the real world... :-)))))))))))
Anyway, thanks for the input.
ARGRTZ
DaDj_
Post by DaDj_ »
about the overscan issue; I have a geforce 4 4600 ultra and i have a overscan function right here in the detonator drivers. Go to the properties of the 2nd monitor/TV! then "Device selection" --> "Device Adjustments" Here you can move the slider of "Screen Size" to the right and TADA!! perfect fit on the tv!
iv0_
Post by iv0_ »
I tryed tvtool with geforce 2 mx and it works fine - it allows you to enlarge the video even more than you need
matrox don't have this kind of problem...
ati radeons, geforce4 and Intel 8XX (we have Intel in our laptop) have the feature built inside the generic drivers
vj.anykey.cz
Basz_
Post by Basz_ »
Hi DaDj,
My setup is Pentium 4 / 2 Ghz / GeForce4 MX 460 AGP
OS is Windows XP / Intel Inside......
But i cant get the underscan problem fixed, and i haven't got that resize slider?????
Is it the wrong driver? I tried the new download of Nvidia site but nope....
I tried a lot of things but the *+^666#@!!! machine wont do it, other suggestions?
Anyone?
Thanks..... peace
