BPM controlled clips - freeze
alchemist
Post by alchemist »
Ok,
finally had a chance to dfo a proper testing in gig situation.
I'll post seperate bugs in separate threads.
First one is bmp controlled clips - for some reason they tend to freeze every now and then. What's interesting, when they freeze (for quite a long time - 0.1-1s) only bpm controlled layers frieze - regular still playback fine. It saves the day, as you can pretend it was on purpose, but still makes a problem. And if you do bpm sync for all of them, then it does look ugly as all of them stop.
Anyt idea why does it happen?
gradek
Post by gradek »
I had similar problems wit BPM clips stuttering and freezing. I noticed that the midi input signal was jumping around a lot, I think for some reason the Electribe that I was connected too was putting out an inconsistent midi clock. causing the clips to restart and stutter and sometimes appear to be frozen.
Synner
Happens to me too
Post by Synner »
I have experienced similar problems after the clip has been playing awhile - it's like Resolume loses the BPM Sync.
I am using and Electribe MX as my BPM source. It puts out rock solid midi clock and is used as my master BPM in my performance system. I have it distributed to all my external hardware as well as VST Synths - everything syncs perfectly - except Resolume.
Synner
alchemist
Post by alchemist »
converting mov's to indeo and installing alternative qtime codecs helped a lot - still some freezes but really ocasional (could be an old MOV assigned in one of the decks) and decks load WAY faster.
there were some problems while using Photon X25 MIDI controller and feeding audio through it . After disabling audio feed problems ceased.
[Edited on 26-11-2006 by alchemist]
